Hi Folks, We have this Miele K8452S Fridge that was freezing food whatever setting it was set to, we fitted a new NTC sensor and it now appears to be working fine apart from now the fast freeze light and number 3 light are flashing continuously. any thoughts anyone. Regards Neil
hello neil, this is an error code. its the appliances way of telling you that there is a fault with the sensor.
did you follow the instructions to fit the sensor correctly?
id be inclined to think that there is an issue with the fitting of the new sensor.
Hi Eldar,
Yes you were spot on, turns out our engineer did not get the new sensor crimped on properly. I personally prefer to solder them on and use heat shrink.
Many Thanks
Neil
