Miele KDN12823S Freezer not working properly
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Miele KDN12823S Freezer not working properly
  • #79192
    brinzlee
    I have a Miele Fridge/Freezer
    Miele KDN12823S
    Serial 96162803
    Initially the Freezer compartment was completely frozen up
    The alarm sounds every morning until its reset. We called a fridge engineer who replaced the main pcb thinking that was the fault, he defrosted the fridge and installed the new pcb which didn’t work at all, this just illuminated all the lights on at the top of the fridge..He then put the old pcb back in and said it was something else and not an economic repair….
    I had another look and noticed a large gap around the door where the door was incorrectly fitted. I have fixed this and now there is no gap, The magnetic seal is also intact with no tears, the freezer now freezes to -20, the fan works when you open the door…but then after 24-36 hours the alarm goes off again and the internal temperature is between 0 and -10 degrees….
    I have taken the inside cover off the evaporator and there is no thick ice on the evaporator blocking the flow of air from the fan. So I assume the defrost heater is working..If I leave the cover off and the door open the evaporator starts to freeze up as it should.
    The Fridge section is unaffected and works normally.
    Could this be a thermostat fault…..I am at a loss…
    Any ideas would be very much welcome
    Thanks in advance
    #408348
    Re: Miele KDN12823S Freezer not working properly
    More likely the freezer evap sensor
    #408349
    brinzlee
    Is the temperature sensor probe the same part number for the fridge as it is for the freezer evaporator….and is it easy to replace…I’ve had a look at the pcb and can see where it plugs into but find it difficult to get to the sensor as its in the middle of the evaporator plate and it won’t budge in the freezer
    #408350
    Order the Liebherr part as it’s the same
    #408351
    brinzlee
    I guess its an NTC thermistor…any idea of the part number from Liebherr…..is it Liebherr 9590142
    http://shop.ukwhitegoods.co.uk/9590142- … zer-sensor
