Miele KFN 8762 SD ed Fridge Freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele KFN 8762 SD ed Fridge Freezer
  • #21766
    djohnston
    Showing F4 on on freezer temp display , Any Help would great.
    #192445
    Seamy
    Re: Miele KFN 8762 SD ed Fridge Freezer
    Its an NTC fault. Think its the one in air duct. Check Fan is working properly, you have to bypass freezer door switch to see if it runs ok, the fans give trouble. Also i’ve had some of the thermistor seals let in moisture. Silicone smeared on seal should sort it out.
    #192446
    expertcat
    BELEIVE f4 IS FREEZER EVAPORATER SENSOR.
    Saying that i have replaced these so many times on the same appliance even changed main pcb and the fault code still comes up
    #192447
    djohnston
    expertcat,you don`t have a part number for the NTC and pcb do you.
    #192448
    gegsy
    Freezer Evap Sensor – 6262480
    Main PCB Up to machine no – 6262471
    Main PCB from machine 14/ – 6630180
    Control PCB Up to machine no – 6262500
    Control PCB from machine 14/ – 6630160
    HTH
    Seamy
    These machines are made for Miele by Liebherr. I had one of these give a lot of this problem F4, model was (8462). When the machine defrosts the seal on the NTC lets in moisture which gives a fault reading. I had one machine that i replaced several components but a month or so down the line it arose again. I disconnected buzzer for customer & on advice of Miele technical sealed NTC probes with silicone. Not heard anything back since.
