Miele KFN12923SD
  • #77516
    djohnston
    WE have got 2 of these models and both have the same fault , freezer is working okay going to the correct temperature but fridge is not cold , don’t think it is due to lack of gas or problem with the compressor , could anyone help please.
    Many thanks
    David
    #402418
    djohnston
    Re: Miele KFN12923SD
    replaced the fridge sensor and it worked till it reached temperature in fridge, once it had went through the defrost in fridge it will not start freezing again in the fridge , if i switch it on and off on the pcb it will start freezing again in the fridge , the temperature in the freezer is fine , i have 2 of these same model both doing the exact same , can anyone help please?
    #402419
    SAMURI
    On your model how many sensors are in the Fridge.
    1 or 2 ? Did you replace an air temperature sensor or evaporator sensor.
    The sensor you should change is the sensor on the rear panel in the fridge.
    If you changed the sensor near the light then you have replaced the wrong sensor.
    If you only have one sensor in the fridge then the other is foamed in and you will need the sensor and mod kit from Miele to replace it.
    It comes with full instructions but is more difficult to replace as you have to identify the sensor connections to the PCB
    The fault you have is the fridge evaporator sensor and this is fitted to the rear panel inside the fridge.
    I think yours is the foamed in type sensor and you need the mod kit to fit the sensor to the rear panel
    Bob
    #402420
    djohnston
    HI SAMURI , IT HAS 1 SENSOR AND IT IS LOCATED NEAR THE BACK WALL ON THE LEFT HAND SIDE.
    #402421
    SAMURI
    This is the air sensor in the fridge for the temperature display.
    The evaporator sensor will be foamed in and the PCB is fitted at the back near the compressor.
    Your will have to order the evaporator sensor mod kit for this model not just a normal sensor Kit.
    This mod is available from Miele and it comes with full instructions.
    Bob
    #402422
    djohnston
    Hi Bob, you wouldn’t happen to know the part number?
    Regards
    David
    #402423
    SAMURI
    I cannot remember the part number but if you phone Miele on
    0845 3650555 option 3 Monday to Friday
    They will be able to give the part number and price
    Bob
