Miele KFN14947 – ICE Cube Unit not working anymore
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Miele KFN14947 – ICE Cube Unit not working anymore
  • #98259
    Rene Von Reth
    Hi All,
    since a few weeks the Ice cube maker is not working anymore. The ice cube holder is filling upwith water as normal. After I have clean everything and set the right water pressure, it produces two or three times ice cubes as normal.
    But then the ice Cube Box is Full of a frozen water lake.
    i assume there are one of the two problems.
    1. The Ice cube tray doesn’t turn around so that the ice cubes can fall into the ice cube container.
    2. The Ice cube tray turns around, but the ice cubes stay in the tray, turning back and is filled up with water again.
    I wonder if anyone had the same problem or know how to fix it, or have a solution.
    thanks in advance
    Rene
    #471588
    Tony R
    Sounds like the ice mould has a crack in it or maybe split, depending on the index number for year of production, you may just require a new ice mould, but there are various repairs and upgrades.
