Re: Miele litlte giant t/d-door pops open during cycle-why?
What model number is it? T5205 T5206? Not sure is it a push button door release type, or pull door? If its the one that operate by push button, usual problems are bad connections on relay at door release circuit board, also check control button board. There should be an electrical circuit diagram included inside every dryer, unless someone has pinched it!
hi mandells – likely to be resettable safety stat on element bank popped out. if it has, just check the ducting and internal pipes to make sure the air flow out is unhindered.
good luck eddie
