Miele not draining
  • #47172
    dna
    Not draining all pipes clear and pump is running. if i take off the pipe to theair chamber it drains into a bucket no prob but as soon as i connect it to the air chamber it doesn’t drain. i have removed the air chamber and it has no blockages. please help 😳
    #292551
    PGS
    Re: Miele not draining
    Is the pump impeller intact ?
    #292552
    Fridge? Dishwasher? Coffee maker?
    #292553
    dna
    It is a washing machine sorry model number W829
    #292554
    Has it got an air-break box in line with the drain hose? If it has it may well be clagged up.
    dna
    Yes i have cleared everything to do with draining, sump hose manifold, drain hoses and air break. Could it be a weak drain pump.
    #292556
    Simon46
    not the dreaded button/coin acting like a butterfly valve?
    S.
    #292557
    philfish
    Has it got the plastic Y piece by the side of the dispenser?if so i would clear the y piece and all the hoses attached to it 1 goes down to drain pump housing 1 to the non return valve and 1 to the dispenser/tub hose. theyhave a nasty habit of causing all sorts of problems.
    phil
