Miele Novatronic W340 overfilling
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele Novatronic W340 overfilling
  • #50316
    boselecta
    Miele W340 Novotronic washing machine
    Machine overfills and the ‘check inlet PC’ neon flashes.
    Have checked the pressure system and it is tottaly clear and the pressure switch hose is also fine!.
    any ideas? thanks in advance.
    #304381
    boselecta
    Also the machine fills initially then after about 5 min it starts to fill and doesnt stop.
    If I put it on the wooolens cycle it just overfills stait away.
    Pressure swich?
    Anybody?
    #304382
    washermanuk
    Re: Miele Novatronic W340 overfilling
    Hi matey it could be pressure switch out of calibration? its part of the 5338845 Power-/Control unit EDPL 106 220-240V Was told by Miele tech never to blow down the pressure pipe with it still connected to the board as this knackers the switch just a warning there 😉
    Also i do get alot of probs with the motorised disp top 5492170 Wat.path cont.un. Detg.disp.top 220-240v the gears go out of sync this can cause weird faults on filling? just check its filling into the correct drawers or a horrible noise like plastic gears slipping? hope this helps Brian
    #304383
    boselecta
    Hi washermanuk,
    going back to have another look, some good pointers there especially about the dispenser top.
    Thanks again for replying
