I can’t figure this out. Empties the water flying no problem when it goes to the drain. But when it spins it won’t empty just throws the water around the drum. I have checked all hoses , even removed the ball. I even put the drain hose directly on the pump to make sure the box at the back wasn’t blocked. Am i missing something, all my hair is nearly pulled out at this stage.. 😕
Re: Miele Novotronic Premier 520 absolutely stumped
breathers maybe? if its one the sides come off, there is a hose from the filter to the dispenser hose and then Y pieced to the rear box. all these need to come off to be cleared. Other than that god knows!
