I have a Miele Novotronic Premier Plus to go out to tonight.. The lady doesn’t know the model number, but says that there is no power.. not even to ‘power on light’.
Since I am not familier with these machines.. other than the obvious checks of ‘fuse, cable, supressor, power switch.’ is there anything on these machines that is indemic that I should be looking at.
open the door manually,then firmly close it again and that will probably sort it .
The latch gets stuck partway open,very common but tends to only happen once per machine .
