Miele novotronic W526 – Aborts wash & rinse light flashi
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele novotronic W526 – Aborts wash & rinse light flashi
  • #59029
    nelson
    I had a look at the known error codes but this doesn’t tally with anything.
    The machine aborts at different points in the program each time it is tried.
    On a 40 deg wash it ran through the wash ok, drained off, spun then filled started to agitate then the rinse light started to flash rapidly, the machine drained then jumped to anti crease / finish.
    On the separate rinse program the machine filled agitated, drained then as began to pick up to spin the rinse light began to flash rapidly and it jumped to anti crease / finish.
    On the spin only program the machine drained then as it was picking up to the spin the rinse light bagan flashing and it jumped to the end.
    The machine has time remaining display, which I would assume would display a fault code but it doesn’t it simply displays three lines.
    When I took the front off the machine I noticed the anti flood was sitting in water, so may well have been triggered, however when I cleared the water and dried the float switch and re-tried the machine I got the same result. (the water was most likely from my customer checking the filter the previous day, he had managed to get it everywhere :rolls: )
    Everything I tested seemed to check out ok, but I am not that familiar with Miele machines 😳 so any pointers or ideas would be great.
    Cheers
    #336528
    trotter
    Re: Miele novotronic W526 – Aborts wash & rinse light fl
    i think seamy is yer man on this one BUT have you checked the brushes?
    #336529
    russell555
    a flashing rinse light means no,or incorrect tacho signal from motor…. suspect bruses… or loose connection at lower electronic board
    #336530
    nelson
    Thanks for the replies, I will check it out tomorrow and report back.
