Miele Novotronic W828 “main wash” light flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele Novotronic W828 “main wash” light flashing
  • #83863
    00derek
    Miele Novotronic W828 “main wash” light is sometimes flashing. Cycle completes normally, and clothes seem to be clean. Problem does not happen every wash. Machine is 15-20 years old and has been problem free up to now.
    I suspect the heating element is either failing or covered in scale and so can’t heat properly, or the temperature sensor is not sensing properly.
    I’m confident I can fix this if someone can give me any suggestions about how to diagnose it further, or what is the most common cause of the main wash light flashing.
    cheers
    #424017
    Seamy
    Re: Miele Novotronic W828 "main wash" light flashing
    F8=
    Main Wash flashing
    Heating error, check heater, NTC, heater relay, connections etc
    Open or short circuit in the NTC temperature sensor or its connections.
    #424018
    00derek
    Thanks.
    What is the resistance of a good element?
    what does NTC stand for?
    cheers
    #424019
    Seamy
    NTC = Negative temperature coefficient (the resistance decreases with increasing temperature)
    Resistance of element should be approx’ 30 ohms, obviously it will vary dependant on wattage of said element.
    2kw element should read 28.8 ohms
    #424020
    00derek
    Thank you!
