Hi gents
The above machine will operate perfectly on drain and spin. On any wash or rinse progs, on starting it flashes either the wash or rinse light respectively for a tenth of a second then illuminates the anti-crease/finish light, at the same time lighting the red PC error light. On a few occasions, it has begun to fill then a rapid chattering noise appears from somewhere behind the front panel and the above error sequence occurs.
My first thought is pressure switch but would like a bit of reassurance!
The machine is at the end of the tightest kitchen virtually boxed in with pipes so not gone any further than checking pump/filter and float switch as yet.
Thanks for your help!
