Miele Novotronic W970 – Intermittant “Check Inlet” light.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele Novotronic W970 – Intermittant “Check Inlet” light.
  • #71018
    fred bloggs
    Hello all, our Miele W970 washing machine about 1 wash in 10 stops mid cycle with the check inlet light flashing. There seems to be plenty of water getting into the machine and after restarting the machine it goes on to complete its cycle. The only maintenance the machine has needed since new is the motor brushes have been replaced (the last time in February this year). What should I check before I have to call Miele? Thanks.
    #379653
    Re: Miele Novotronic W970 – Intermittant "Check Inlet" light
    the problem with these type of faults is it does not happen every time
    as all machine get old things perish and miele’s are not immune. my first thought would be inlet valves it may be getting enough water in but is it going in quick enough (i.e. is the valve not opening fully )
    dave
    #379654
    long shot
    when it does it is it full of towels ie needs more water ?
    fred bloggs
    Thanks for the thoughts. It does seem random when the light comes on. I think I’ll have to leave it to get worse until I call the Miele man out. I don’t want to pay for a call out and him not find a definite fault.
    #379656
    Seamy
    The machine is most lkely gunged up, the water level detecting is not working properly, run a cleaner through it to see if it helps.
    #379657
    comcat1
    If its the hose with the water proof system the valves jam up internally and needs the hose replacing, a sign of this is excessive buzzing during filling
