Miele Premier 300 lost power mid cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele Premier 300 lost power mid cycle
  • #99233
    Catch All
    As if a fuse blew – no lights, nothing.
    Checked fuses
    Door interlock switch appears ok
    Is this symptomatic of something common I can go pursue?
    #475553
    have you opened and close the door again ?
    Catch All
    Many times…
    #475555
    i would double check door lock first as on earlier miele units the door lock cuts the power to the panel
    does the door still open with the button ?
    Catch All
    The switch contacts on the door switch look ok. The door can only be opened with the pull in the hatch
    #475557
    have you checked socket ?
    Catch All
    Yes, as per first post fuses are all ok. And there is power from the socket….
    #475559
    well the next thing i would check is to see if power is getting to the board
    Catch All
    May have to get someone in to have a look. Was only able to get as far as confirming power was getting as far as the suppressor where the power comes in… Not sure how to get at the board.
    #475561
    check your getting both live and neutral at the supressor
    yes a bit tricky to get the board out. am sure if you look someone will have done a utube video
