Good morning.
I’m at this machine right now. When turned on the pump starts running continuous. If I select a cycle it fills whilst draining the check inlet comes on.
If I select spin it spins perfect pump running all time even after spin and in anti crease. I have of course established that float switch is working as it aborts if manually activated. (I’m running it with front panel off).
Any advice much appreciated although I suspect that pump switch on pcb will be shorted.
