miele premier w500
  • #50151
    kwaremont
    hi this one fills runs for 5 mins then rinse light flashes what code is this thanks,
    #303787
    philfish
    Re: miele premier w500
    no signal from motor tacho check brushs etc.
    phil
    #303788
    kwaremont
    thanks phil
    #303789
    dal
    def amotor fault ? But i had same type off fault turned out to be a broken wire that goes to the motor plug wires it had broken but still was hanging on by the plastic covering Good hunting Regards larry @dal
    #303790
    washermanuk
    Motors from Miele carry a 10 year gaurantee, but Miele must fit em!! :rolls:
    #303791
    clayside
    I think you will find only motors with 10 year g/tee are the brushless type
    clayside
