miele prestige plus
  • #33307
    dunpony
    Does anyone know if the soak function is for a cold soak, or is it maintained at the temp selected for the wash?
    #238234
    don
    Re: miele prestige plus
    If you can hang on until Wednesday I`ll check out the instructions on the display model I have.
    Don
    #238235
    clayside
    If my menory is correct machine soaks with cold water from 30 minutes to 2hours in 30 minute steps. Machine then uses this water for main wash.
    your can download copy of instruction book from miele.co.uk then go to customer support / instructon books.
    raegards clayside
    #238236
    dunpony
    Thanks guys. I have the instructuions that came with the machine but they don’t specify! (or at least I can’t find it :rolls: )
    #238237
    don
    Reading the instructions I would say it`s cold soak only which can be set for a length of time from 30 minutes to two hours in 30 min increments.
    The definitive answer would be to phone Miele direct on 01235 -554455
    HTH
    Don
