Miele prestige plus 6 – keeps tripping our RCD please help!!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele prestige plus 6 – keeps tripping our RCD please help!!
  • #81978
    Andrewkirk
    Please help
    Our Miele just started flipping the main RCD switch in our consumer unit every time I switch it on (so all our lights go off!) I have tried it on a rinse cycle but again it flips the main RCD.
    We opened the top up and by trial and error (and advise from a generic engineer) we unplugged one of the black plugs (marked with a no17) and it seems to be working. However we are not sure what we have unplugged so cannot continue to use it.
    Please advise, many thanks
    #418327
    Re: Miele prestige plus 6 – keeps tripping our RCD please he
    Follow the wires and you’ll figure out what the problem is. 😉
    Andrewkirk
    I can’t follow the wire as it goes into an encased unit which runs down the front of the machine with other wires. Anyone got a wiring diagram? Thanks
    #418329
    Muv
    That unit you unplugged is the relay for the water heater,so you could have a faulty relay,or a faulty heater itself.. You need tontake the front of the machine off to further inspect the heater…power off at all times. Zap!!
    You may find a diagram tucked away in the front as well
    Muv
    Could you supply us with a side view of the unit you unplugged. And possibly a view of the whole top view of the machine?
    The heater relay is usually on tje right hand side, and is a orange/tan color plastic unit.
    Judging by the thickness of the black wires connected to it I’m almost certain its the heater relay
    #418331
    Andrewkirk
    Thanks for your replies, will post another photo when get home to open it up. How would I know if it was the heater or the relay when I do look at it? Without having to buy both! Thanks!
