Miele Professional Dishwasher Mod. G7859
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele Professional Dishwasher Mod. G7859
  • #49224
    Ashby
    Hi, Anyone familiar with this machine?
    A white film is being left on the dishes and on the inside of the machine.
    I’ve tried to reset the salt level intake as per instructions, by holding down the start and temp buttons together and switching on. The programme status “P” should appear and also the “Tap/Drain” indicator should light up. I’m getting Nothing on the display at all.
    Thanks for your help.
    Ashby
    #299216
    russell555
    Re: Miele Professional Dishwasher Mod. G7859
    make sure the dial is at the 12 o clock position when switching on…. once you get to the salt level feature set it to 19… this is the right setting unless there is a built in softener on site..then 16 is your best bet
    #299217
    Ashby
    Hi, Thanks for your reply. Yes, the dial was in the 12 O’Clock position,but still no joy. They have 2 machines exactly the same model and i tried this on the other machine and it worked? Any other ideas?
    Much apreciated.
    Ashby
    #299218
    Ashby
    Hi, Anyone have any ideas on this one please?
    Many thanks.
    Ashby
    #299219
    Ashby
    No Miele experts on here?
    #299220
    russell555
    out of curiosity ,if you were to switch off at the wall and on while holding down b and c (a=top c=bottom b=middle)does it go into programming mode??? its been known for the live on the on-off button to weld shut,causing the main control board to only switch neutral….
    what hapens if you switch on holding down a & b… if it says s21 in the display ,sounds silly but it may be easier to remove the facia panel and push the buttons without it in place,as if the contact is not great when you turn the power on it will not regester the buttons being pressed
    #299221
    Ashby
    Many thanks for your help, i will try that.
    Much appreciated.
    Ashby
    #299222
    Ashby
    Me Again! Just had a call to say the other machine is showing a fault code F26?
    I don’t have a copy of these.
    Can someone help? Please!
    Thanks.
    Ashby
    #299223
    russell555
    f26= flooded base… either the drain pump…or the ring holding the inlet chamber on the right hand side of the cabinet inside is loose
    #299224
    Ashby
    Hi Russell,
    Many thanks for your help.Again!
    Much appreciated.
    Ashby
    #299225
    Ashby
    Hi, The drain pump on this machine needs replacing.
    Where is the best place to get one please, and could you give me an idea of the cost?
    Many thanks.
    Ashby 😆
