Miele PT7135C Condenser Tumble Dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele PT7135C Condenser Tumble Dryer
  • #85626
    WhiteVanMan1
    Dryer runs on Iron Dry Normal for about four minutes then stops. I checked for blockages etc, all seems ok, and it ran ok on timed dry. NTC perhaps? Any ideas would be greatly appreciated. Cheers. Steve.
    #429089
    Re: Miele PT7135C Condenser Tumble Dryer
    did you run it with wet clothes in
    if machine does not detect dampness wont heat and aborts prog
    what i do with miele’s ia get a wet peice of kitchen roll or a wet cloth (wet not dripping) and balance it on the brush gear at the top of the machine
    WhiteVanMan1
    Thanks Dave. Yes I did check that it wasn’t just a customer misuse problem. There is definitely a problem here but there is no fault code, just a technical fault message in the display. Steve.
    #429091
    miele sense the drying by using a brush gear on the drum
    are brushes and wires ok ?
