Miele PW5065 Poor Spin Performance
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele PW5065 Poor Spin Performance
  • #58798
    conormccleane
    Hello,
    Is the motor on this machine a sealed unit i.e. no brushes to replace? A customer has problems with clothes coming out wet after spin. Also, is the pressure switch built into the control electronic? I haven’t called to the machine yet but would like to have some feedback before I call.
    Thanks,
    Conor!
    #335724
    washermanuk
    Re: Miele PW5065 Poor Spin Performance
    No carbons on this and its a 3 phase motor but tacho is available as a seperate item
    pressure switch is built on the control pcb
    dont blow up the pipe to check if pressure switch works as this puts the calibration out 😥 not worked on any of these so cannot give you any more help regards Brian
    #335725
    not sure about this model but a regular on other Miele’s is the pipe from the Y join on the dispenser hose down to the top of the filter. Take the side panel off and you can see it easily, take all the pipes off and flush them out.
    #335726
    conormccleane
    Thanks for the replies,
    Checked out the fault memory on the machine and deleted it – don’t know how long they have been on machine – will call back this week to see what new faults if any have been logged. Faults logged were:
    F47 – BAE/SLT Interface Defective
    F39 – Vacant
    F11 – Water Drainage
    F16 – Foam/Excess Detergent
    F50 – Drive
    F15 – Water Intake Fault – Hot
    What is a BAE/SLT Interface? and what does an F50 – Drive fault suggest?
    Conor!
