Miele PW6055 Plus LP washing machine
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele PW6055 Plus LP washing machine
  • #75832
    TonyMower
    Don’t know if anyone has had this problem, we have visited the above Miele with no display, looking at the wiring diagram we suspected it could be the interlock or the push button switch but neither cured it. As the new display module is £500 plus we don’t really want to order it without being 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure! Has anyone had this problem or knows of a test to prove the module is faulty?
    Thanks in advance.
    #396293
    Re: Miele PW6055 Plus LP washing machine
    have not seen module on this machine but had an earlier model that started then ther display went off W1514 series
    on that machine it turned out to be a 5v regulator chip going faulty under load but it could equally have been not working which would have caused blank display
    check board for regulator chips and power supply problems as it may be a switch mode power supply fault or a transformer it it has one
    TonyMower
    Thanks for that, I would assume both the chip and switch would be found on the power module?
    #396295
    where ever the mains goes to first after that the voltages drop to lower than 50v normaly 12 or 24 plus 5v for the logic chips
    if you look at the relays on the board they normally have a voltage on top of them that will give you the higher voltage
    is the display board just a display or is there a logic board with it? if there is a logic board then there may well be a 5v reg chip on that board. if you look around at the electrolytic capacitors they have a voltage on the side and this will let you know what to expect
    TonyMower
    Thanks Dave we will have a close look at the Logic board
    #396297
    Taff
    I’ve has two Miele’s recently with the same problem. I sent both boards to QER for test/repair. Both came back with the main chip blown. Both machines scrapped due to cost of boards. Main problem being that a fault could exist on the machine which caused the board to blow, fitting a new board could cause the same fault on the new board.
    #396298
    TonyMower
    Thanks for the information Taff, I think sending the boards to QER is our next step
