Hi i Have a miele commercial washing machine that overfills until water pours out the soap drawer no blockages in the pressure pipe or holes . The pressure pipe seems to go into what looks like a pressure switch but isnt then out the other side and up onto the main circuit board . the inlet celenoids switch the water off if the power is turned off . not seen this fault before so any help appreciated Thanks Rich
it is suprising it does not fault code out with the time its taking to fill
check the hose for any leaks. the pressure switch will be the one on the board
dont know what the other one is but needs to be checked for leaks whatever it is
if you want to post a picture of it will take a look
Normally it’s the plastic pipe which is at the bottom of the tub under the door seal.Normally full of scum and stopping the pressure switch from working correctly.
The front of the appliance will need to be opened to access.
