Re: Miele red light drain error problem
Thanks for that, I will try what you suggested. If there isn’t any water on the floor are there any other things to try?
There is sitting water in the bottom of the machine in the filter basket area, should that be empty? When I took off the non return valve to check the impeller, a fair bit of water spurted out.
Wonder why it worked initially and then stopped on the second run. If there is a leak, is it curable?
