Miele s5210 vacuum cleaner
  • #56550
    bmrenr
    Hi I have the above vacuum will not work since customer sucked up a piece of a blanket . I have taken it apart and found what looks to be an overload protection on the motor. its a small pcb that plugs into the motor and on that is a fuse of some sort I think with one of its legs going into the pcb melted and printed on this is 3mp33101 and underneath is 20t6saaw and on the back is klixon. does anyone know what this is and where i can get one I have rang Miele and they will only sell the motor for 200 euro.
    Tom.
    #327921
    Re: Miele s5210 vacuum cleaner
    Klixon is a name i associate with thermal cut outs on fridge freezers etc
    hope this helps
    Seamy
    Its a thermal cut-out device to prevent the motor from overheating when a customer sucks up a rug. Have found some of these boards on the motor to be problematic with dry joints etc.
    #327923
    bmrenr
    Cheers guys I managed to solder a leg onto it and the vacuum is running again but is very noisy sounds like the motor is on its way out. would I be right or is there anything else im missing.
    Tom.
    #327924
    Vane on the fan blade broken?
