Anyone any advice on the condition. Power to and through switch. Then nothing. Motor fine. Think pcb may be faulty but don’t want to buy if anyone has other solutions.
Andysam
Check if main PCB receives 220V (measure directly on voltage transformer from PCB). If not then verify where is disconnected (you have there wiring/connection diagram) follow wires thru motor cut-out and switch panel block… :rolls:
