Miele T220 dryer seal
  • #28897
    Simon46
    How do i fit this seal 5860450? does the seal fit between the cabinet(stripdown) or just push in to a groove? Never repaired A Miele before.
    Regards
    Simon
    #220573
    Seamy
    Re: Miele T220 dryer seal
    Just pushes into a groove when front is off..
    #220574
    Simon46
    Thanks Seamy. Is there any hidden screws to remove front?
    S.
    #220575
    Seamy
    Yeah theres two hidden beneath plinth..
    This should guide you:-
    Open the door..
    Remove screws from the interlock..
    Remove screws around the door opening..
    Remove the screw caps from plinth..
    Remove plinth fixing screws..
    Slide plinth slightly to left to unclip & remove it..
    Remove 2 screws from bottom edge of front panel..
    Now pull front panel out at the bottom & release it from under facia..
    #220576
    Simon46
    Thank you so much. I really appreciate this. 😀
    S.
    #220577
    Simon46
    After all that the new seal just pushes in to a groove if you open the door 😆
    Part no is superceded though.
    Thanks all
    S.
