MIELE T230C dryer
  • #44246
    trotter
    Runs through the drying cycle (Normal) getting full current draw from heater – and heat!
    At end of cycle clothes are hot/damp. Checked for blockages inc condenser water is pumping okay into drawer. Tested for continuity between straps of sensor to drum – one to earth & one not, which I believe is correct?
    Cleaned sensors on inside of dryer, still the same results. Dryer appears to run through cycle perfectly well indicating each stage of drying – but clothes are not dry, just warm & damp.
    ANY IDEAS PLEASE?
    #280371
    trotter
    Re: MIELE T230C dryer
    AND…………just to confuse things even more. I have just tried swapping the control board with another machine ….no difference! and the donor machine is still working perfectly :rolls:
    SEAMY…….Where are you ❓
