Miele T234C Very Steamy – Not much condensing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele T234C Very Steamy – Not much condensing
  • #54245
    dan_uk_1984
    As per thet title, our T234C is very steamy when one opens the door. Also I don’t think it’s condensing as it should as there is very little water in the water collector.
    All filters are clear, it has new brushes and a new cut out switch.
    Thanks,
    Dan
    #318949
    Re: Miele T234C Very Steamy – Not much condensing
    Blockage, failed pump.
    dan_uk_1984
    Hi, Thanks for your reply.
    I’ve checked the drain tube and that seemed fine. It just seems to take slightly longer than normal, plus there was a some condensation inside the machine when I took the lid off.
    Dan
    #318951
    washermanuk
    check the condenser seals and if the bottom fan is running?
