I have a T270C which starts as normal – heats – drum turns. On any programme selection (Apart from cool air)after around 6 or 7 minutes the buzzer sounds continuously with the following lights.
Buzzer: constant light
Cool air: constant light
Hand iron: Flashing
Checked airways and all pretty good condenser not perfect but clear enough. Almost seems like an overheat problem? Im only guessing because the one shot is still intact, is there a sensor I need to check and if so where the heck do I find it?
Many thanks for the shedload of instant responses 😆
