Re: Miele T284 tumble dryer
Its always that relay board at the back in my experience, it may look fine. If it has 3 rectangular relays on it then its the old style and will be the cause of no heat, the new version has 4 square relays and is far more reliable. I have replaced the relays on one of the old boards which I use for testing or temp use while the correct one is ordered but it was a bit of a trial due to the double sided soldering and I wont bother again. Don’t expect any change from £100 quids though. 😯
