Miele T294C
  • #64493
    ChrisR
    Hi guys
    This drier does not heat.
    Element checks out ok but no supply to heater from pcb next to mains suppressor.
    Does the pcb need to be changed or is there another underlying cause.
    No experience of this model so all advice gratefully received.
    Regards.
    Chris 😀
    #357230
    clayside
    Re: Miele T294C
    Yes nomally it’s that board mounted at top part no 6912041
    clayside
    #357231
    ChrisR
    Re: Miele T294C
    Thanks mate
    #357232
    ChrisR
    Re: Miele T294C
    Hi clayside
    Are these boards fixable or do I have to pay £92 for a new one.
    Cheers
    Chris
    #357233
    steve1
    Re: Miele T294C
    hi chris
    i had the same fault on the same dryer a month ago, no body could repair the board had to get new one from miele,(slightly cheaper than connect)
    steve
    #357234
    ChrisR
    Re: Miele T294C
    Thanks Steve
    Have you got a number for
    Miele parts
    Cheers
    #357235
    Re: Miele T294C
    ChrisR wrote:Hi clayside
    Cheers
    Chris
    I did actually change the relays on one of these once as there is nothing else on the board. The double sided nature of the board made it a pig of a job having to butcher the old relays to get at the pins but it did work. having said that, there is obviously an issue with these boards as the new one has an extra relay on it. In hindsight, I will now recommend going for a new board, it aint cheap though! but then no one is going to dump a Miele drier for the sake of the cost of it. Miele spares is:08453656605 or 01235233133
    #357236
    ChrisR
    Re: Miele T294C
    Thanks for that.
    Regards
    Chris
    #357237
    steve1
    Re: Miele T294C
    hi chris
    miele Spare parts enquiries
    0845 365 6605
    cheers steve
