Miele T294C Condenser dryer TOC
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Miele T294C Condenser dryer TOC
  • #50957
    boselecta
    I require the TOC situated on the heater element. Part number please.
    thanks
    #306460
    clayside
    Re: Miele T294C Condenser dryer TOC
    Part no for thermostat 5432490
    clayside
    #306461
    boselecta
    thanks clayside.
    #306462
    johnrudge
    Hi there. Does anyone know the value of this TOC so that I can purchase a cheaper one (a none Miele part). Thanks for your help..
    John Rudge IOW
    #306463
    Seamy
    Value is normally printed on the side of T.O.C if you still have it, it may be 175c 😉
    check current rating is same though if you don’t use genuine
    http://www.espares.co.uk/part/tumble-dr … ermos.html
    #306464
    did one yesterday, 160
    #306465
    trotter
    Don’t forget to keep the old one and try putting it in the freezer – they sometimes reset!
    #306466
    trotter wrote:Don’t forget to keep the old one and try putting it in the freezer – they sometimes reset!
    heard this from a reliable source in the past but not once has it ever worked for me! tried weeks in freezer and using freeze it spray with no luck on any type of toc at all.
    #306467
    johnrudge
    many thanks guys 8) 😕
    #306468
    trotter
    Only tried it once and it worked….didn’t work with freezer spray though. Anyway it is worth a go they don’t take up much space in the freezer, hey I wonder if it works in a frost free freezer? maybe that was the problem! :rolls:
    #306469
    washtronics
    i reset lots of toc by dropping onto concrete from 2metres height, works every time. make sure you drop it metal side down
