Miele T294C Condensor dryer starts then stops and beeps
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Miele T294C Condensor dryer starts then stops and beeps
  • #64045
    kitchencare
    hiya,
    this works fine on the timed 30 or 15 minute programmes but on any other programme it starts and then within approx 1 mins it stops and beeps. it won’t heat on any programmes except the timed ones. It is clear of blockages and the element and stats at the back are ok. Trying to get help out of Miele is impossible as you know! I am guessing turbidity sensor?
    Any ideas appreciated.
    #355869
    Seamy
    Re: Miele T294C Condensor dryer starts then stops and beeps
    Sounds like there is no clothing in the dryer & in automatic (sensor drying) setting the appliance shuts off as it doesn’t sense any damp clothing in dryer.
    Read the instruction manual that came with your appliance, it says
    “If there is no laundry in the drum when the programme is started,
    the electronics will register this and stop the programme. The
    programme will also be interrupted if the laundry placed in the drum
    is already dry.”
    #355870
    glynskipper
    hi if you take the lid offin the back right hand corner ther is a pcb which can faulty and you will have no neutral to heaters
