Miele t4262c stops after 20 seconds
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele t4262c stops after 20 seconds
  • #84008
    slyp98
    Hi guys this dryer has a over heat stat blown , replaced stat now only runs foe 20 seconds , no error code anyone have diagnostic info cheers
    #424489
    clayside
    Re: Miele t4262c stops after 20 seconds
    Have you tried with damp load as machine has load sensor and will stop after approx. 20 seconds without.
    clayside
    #424490
    slyp98
    no didnt try damp clothes , will get customer to check it thanks
    #424491
    slyp98
    No joy with the damp clothes , any other suggestions thanks
    #424492
    slyp98
    bump
    #424493
    Muv
    Check the carbon blocks on top of the drum,they may be worn?
    slyp98
    first thing i looked at Muv , all present and correct
    #424495
    is it heating? and when you says “stops” do you mean with alarm sounding? If its not heating it may well stop after a minute or so but AFAIK the alarm sounds. Poss heater relay board if so. There is a “warm air” dry setting which should by pass all the dryng senors and run for 20 minutes (or how ever long it says on the dial.)
    #424496
    slyp98
    I can hear the relay click and sends power to the element, and it stops then with the beeping alarm it only takes 10 to 15 seconds for this to happen , I see a sensor similar to an oven temp sensor beside the overheat stat on the element housing 2 wires coming off it going back to the timer anyway of finding what id anything is wrong with that
    #424497
    slyp98
    BUMP
