Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › MIELE T430 no motor action
- This topic has 7 replies, 3 voices, and was last updated 18 years, 2 months ago by
trotter.
February 6, 2008 at 2:13 pm #34377
trotter
ParticipantNice day huh? 😆
I have a Miele T430 in pieces in the workshop. I am getting no motor action – customer reported this before and having defluffed an extremely blocked up vent it worked okay.
Now when I switch on I can get the door lock to operate,light comes on when door is open off when closed etc.
the heater switches on ……..but….NO MOTOR ACTION capacitor or nmotor maybe?
HELP PLEASE ❓
February 6, 2008 at 9:00 pm #242368msappliance
ParticipantRe: MIELE T430 no motor action
i would normally say the electronic board.
February 6, 2008 at 10:08 pm #242369trotter
I think I am gonna go for that……bit pricey but hey it’s only money 😆 I did check for dry joints and the relay that I think switches the motor seems fine.
I even took the cover off the relays and switched them with a small screwdriver & they were reading okay.
Guess I will have to bite the bullet and try the board I will post the result on here………Thanks for your input 🙂
February 7, 2008 at 10:56 am #242370Seamy
Tap relays on board, they are prone to sticking. Also check for the normal things like bad connnections at edge connections to PCB.
February 7, 2008 at 4:06 pm #242371trotter
Thanks for that seamy, I am certainly not sure about the board …..but I have looked for dry joints etc.
Am I right in thinking that REL 1 switches the motor?
Again!February 7, 2008 at 4:31 pm #242372trotter
AHA !!!!
The answer to that is NO it is REL2……I know that now ‘cos I just found that REL2 has an o/c coil and if I switch it manualy the motor runs….. 😆
is a relay available…………not sure yet!
February 7, 2008 at 6:32 pm #242373Seamy
Sent you a PM Trotter, best of luck in sourcing relay as board is £160ish
February 12, 2008 at 1:11 pm #242374trotter
Thanks Seamy…..found a great company that supplied a relay to do the job. (rapidonline.com)
just fitted relay to board and…….IT WORKS! …. YIPPEE
Many thanks for all the help.
