Miele T490
  • #67029
    bazza500
    Anyone have the part numbers for the heater relay and drum carbons on this tumble dryer please.
    Barrie
    #366022
    don
    Re: Miele T490
    Hi Barrie
    Have a look at the two drawings and let me know which positions you are after.
    The part numbers will be on the old parts if you have them 😉
    Don
    #366023
    bazza500
    Re: Miele T490
    Hi Don,
    Your drawings are a bit small but I can get the drawings up on Connect and it’s part no. 9 on the components drawing and 41 (I think) on your top drawing.
    Do you have the part numbers for these?
    #366024
    don
    Re: Miele T490
    Hi Barrie
    Item 41 on drum page is indeed the carbons part no. 4490382 but no. 9 is a rubber cushion.
    Don
    #366025
    bazza500
    Re: Miele T490
    Hi Don.
    Thanks for the carbons number. The number 9 is not on the drawings you have posted but is on the Connect site under the drawing called “components”. Can ytou get the part number from that?
    Thanks, Barrie
    #366026
    bazza500
    Re: Miele T490
    Having read a few posts on this forum it would seem that the carbons being worn and jumping off the nut would cause it not to heat. Is this right?
    … and is there an easy way to get the belt back on?
    #366027
    don
    Re: Miele T490
    bazza500 wrote:Hi Don.
    Thanks, Barrie
    Relay is 4028320
    Don
    #366028
    bazza500
    Re: Miele T490
    bazza500 wrote:Having read a few posts on this forum it would seem that the carbons being worn and jumping off the nut would cause it not to heat. Is this right?
    Anyone know the answers to these questions?
