miele T490 tumble Dryer no heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries miele T490 tumble Dryer no heat
  • #67709
    mike100
    This one not heating. had heater out, it looks ok and toc is ok.
    Tried it with damp cloth still no heat
    The sensor brushes are making a real racket when drum turns.
    Would the brushes stop the heater from coming on.
    Any help please
    Mike
    #368249
    Re: miele T490 tumble Dryer no heat
    its unlikely the senasor brushes are causing your problem. noise from brushes usually come from the frame catcing a screw as the drum turns
    first check all ntc if you cant get enough damp material inside drum you can put a bit of damp cloth between the two brushes
    lastly if all this fails check relays on pcb
