Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Miele T5205c dryer
- This topic has 7 replies, 5 voices, and was last updated 17 years ago by
Dapman.
March 14, 2009 at 3:33 pm #44231
Dapman
ParticipantHi can anyone tell me how to remove the drum on this machine.I need to get to the heater due to earth fault.I have the machine opened up and front drum support removed.
thanks Dave.
March 14, 2009 at 4:06 pm #280279chezza
ParticipantRe: Miele T5205c dryer
if you look through the back of the drum, while slowly turning, there are some allen screws ( 2 or 3 )..undo and voila !
March 15, 2009 at 12:58 pm #280280Dapman
Hi Chezza
I can see hex head bolts or screws through the holes in back of drum, the problem now is the holes in the drum are not big enough to pass a spinner through to undo.Please advise.thanks Dave.
March 15, 2009 at 1:03 pm #280281Seamy
Undo hex screws, back plate of drum comes off, you will then get access to heater, not a difficult repair to be honest.
March 15, 2009 at 1:06 pm #280282Penguin45
Dapman wrote:the problem now is the holes in the drum are not big enough to pass a spinner through to undo.
One of them is……..
March 15, 2009 at 2:19 pm #280283Dapman
Hi Guys
Sorry to be a pain.The six large outer hex screws when removed do not allow the drum to be removed because the inner plate is much larger than the aperture in the drum.The holes in the plate which the hot air blows through are all the same size and just big enough to pass a philips screwdriver through thus unable to undo small hex screws.Can supply photo if required.Thanks again.
March 15, 2009 at 4:04 pm #280284philfish
if its how i remember there will be 2 larger holes near the centre of the back panel that you position diagonal at quater to 3 position undo allen keys which you can see through the 2bigger holes 7mm if i recall and then undo all allen keys around back plate back plate should then come off leaving 3 or 4 7mm screws undo them and heater bank slides out.
hope that helps.
philMarch 17, 2009 at 10:44 pm #280285Dapman
Hi Guys
thanks for all your help,i did find the alan screws.I was looking to far out,you would not find them by chance.Cheers Dave.
