miele t650c
  • #41939
    robbo1973
    been here today and the fault is when you set it on the cycle it runs for about 5 secs something kicks in like a fan on the bottom runs for about another 5 secs then goes to end on opening the door no heat.question how do you get into this beast? wrap round cab and is there an easy way to get to the heater?
    never worked on one before.
    cheers chris
    #271798
    Re: miele t650c
    its all through the back of the drum, the ring of hex screws you can see and then there are 2 hidden screws either side of the drum bearing that are reachable through the 2 slightly larger holes in the drum rear. (use a torch, you will the the hex heads) The nuts are captive so dont worry about them. Lot easier than it first appears.
    #271799
    chezza
    Re: miele t650c
    if door opens on it’s own, this is usually down to o/heat stat tripping ; check ducting isn’t restricted ( resettable stat on the internal lower ducting )
