Miele taco coil
  • #93361
    mbdas
    Hi can anyone give me the part number for the Taco coil on a Miele W3830 Nr41/85716037 I’ve tried phoning and Emailing them but getting no response,it’s not a make I have much to do with so could well be a new motor.
    Regards mark
    #454086
    Re: Miele taco coil
    ring miele direct spares
    they will give you a part number and price for the part
    As an alternative there are lots of motors available on ebay for miele had had a few that way. look on the motor plate for the number (like MRT37 – 606/2) and search. I always email seller and ask are bearings quiet and ask if it clicks as it turns if no order and your backed by paypal. Got one faulty one and papal came down on my side
    Not had a tacho fail, assume coil is open circuit. Have you looked carefully at it. most of the time they break at the ends and with a jeweller eye glass a quick scrape and solder and all is well
    don
    Re: Miele taco coil
    I have all Miele parts look up function 🙂
    The Annular magnet 8-polig mit schraube is part no.4879581 round about the £20 plus VAT 😆
    Don
    #454088
    Re: Miele taco coil
    is this a brush type motor? if so the coil is part of the carbon brush module £££!
    #454089
    don
    Re: Miele taco coil
    eastlmark wrote:is this a brush type motor? if so the coil is part of the carbon brush module £££!
    Doesn’t look like it does Mark but then again I could be wrong.
    Don
    #454090
    Re: Miele taco coil
    item 5 is just the magnet
    the coil is part of item 2
    as far as I know
    which item did you give the number for ?
    Re: Miele taco coil
    yes the coil is part of item 2 be prepared for a shock! there are digital versions so serial number is essential and no access to the windings for a repair afaik. but at least you can console the customer by telling them they get a free pair of brushes.
