miele tumble dryer
  • #29940
    abbots
    hi guys,
    can any one point me in the right direction to removing the front panel of a T5206 dryer please.
    i removed the 4 hex. screws from the front around the door opening but something is still holding it,any advise will be much appreciated.
    ta.
    john
    #225259
    WhiteVanMan1
    Re: miele tumble dryer
    Not sure of this model, but all miele TD’s I’ve come across have one or two screws top left behind removable panel. Sometimes a screw bottom left, but usually just a spring clip.
    #225260
    abbots
    cheers,
    this is a commercial one, don’t know if that makes any difference?
    does the front”open up” like a door, ie. hinged,like the washing machines used to?
    ta.
    john
    #225261
    WhiteVanMan1
    Yes, they usually hinge on the right hand side like the washers
    #225262
    abbots
    cheers lads
    #225263
    Seamy
    Remove the facia panel at front, insert a small screwdriver and push downwards. This will reveal screws behind. 💡
    #225264
    abbots
    great stuff,
    sorry, can you just clarify that please.
    i take it you mean to remove the upper plastic consol panel you insert screwdriver in somewhere.
    or do you mean to remove the machine metal front panel you insert a screwdriver.
    sorry, but i haven’t done one before and i don’t want to damage it.
    ta,
    john
    #225265
    Seamy
    Remove 4 screws around door
    Remove top LHS facia by prizing it down with small screwdriver to reveal 2 hidden screws, small panel removes revealing more screws, remove screws.
    Loosen torx screw on RHS of this small panel and move screw down to release catch.
    On botton LHS release spring catch to release front panel which should hinge open.
    Hope this helps..
    PM me with e-mail address if you need any other info.
    #225266
    abbots
    thanks buddy,
    sorted out thanks to you.
    jk
