Have this meile T586C and the heater nad thermostat have gone. Spent about 1hr stripping it down to test the heater which i faound but cant work out how to take it out. PLease help !!!!!!!!!!!!!!!!!! 😕 😕 😕 😕
I newly got it out but it seems that the manifold at the bottom will also have to come out. But still cant work out how the heater will come out i have taken the drum plate off which is held in by 6 machine screws. but thiis seems to have rivots also which are connected to the heater metal ducting in some way. really confused.
are they easy to spot because i can only see 3 nuts that are for the heater. must have missed the other ones. is it right that the heater is £150. approx
As you look into drum, backplate section comes off. There are machine screws/allen head screws. Two of these are hidden & you may have to turn drum to locate these. Heater can then be located & is secured by 2 screws these can be removed & heater assembly taken out. 2 Thermostats on early type heater & one ‘stat on newer type.
