Miele Tumble Dryer T7634?????????
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Miele Tumble Dryer T7634?????????
  • #64238
    steve1
    hi guys
    does anyone have a wiring diagram for a Miele Tumble Dryer T7634 ??
    i also need a complete heater assy, who is the best / chapest supplier?
    thanks
    steve
    #356488
    don
    Re: Miele Tumble Dryer T7634?????????
    Hi steve
    Part number for the heater box which comes complete with stat and sensor stat 6252815.
    I’m sure someone will be able to help with the wiring diagram 😉
    Don
    #356489
    steve1
    thanks everyone
    don the part number you gave is the same one i have just wanted to confirm, sorted out the wiring now i dont need a diagram
    thanks
    steve
    #356490
    not saying your wrong Don but every miele drier heater I ever order does not come with the saftey stat or ntc. Not in a position to check now but watch out, dont get caught out like I did the first time. Given the cost I expected it to come complete.
    Usually a wiring diagram tucked under the lid.
    #356491
    don
    Thanks for the heads up Mark.
    Just checked the drawing and parts list again for peace of mind incase I had made a booboo 😆 on closer investigation It does look like there are three different versions dependant on machine number though, you may need to check this number Steve just to be on the safe side.
    The heater box comes as pos no. 20-23 and the stats are listed seperately as well on pos 21-23.
    20-23 6252815 1 units Heater bank 1,94/2,65kW 230V
    From mach.no 94901258 Up to mach.no 54/
    20-23 6810341 1 units Heater bank 1,94/2,65kW 230V
    From mach.no 55/
    20-23 7083600 1 units Heater bank 1,94/2,65KW 230V
    21 5520870 ** 1 units -Thermostat 60T05-502683 175°C
    21 6671690 1 units -Thermostat 60T05-502709 175GRAD
    22 5435971 ** 1 units -Temperature sensor NTC 040033
    22 5435972 1 units -Temperature sensor NTC 040044
    23 4102150 1 units -Plug housing 3 pole
    Don
