This tumble dryer is leaking from the condensing box and spilling over to the left side onto the insulation thus causing drips and manifesting into a puddle.
I traced the source of the leak which appears to be that on the rear of the heat exchanger box that the seal is not maintaining a tight seal against the rear exhaust channel.
Is there a replacement seal for this or do I need to replace the entire heat exchanger?
