look at the back of the drum inside. look through the holes at the centre rear. there are 2 allen keys one at 9 0clock the other at 3. once the front and belt is off you need to undo these to release it from the rear bearing
sorry, I omitted you also need to remove the Allen head bolts around the back plate from inside the drum. Once that is off, you can access the heater and one shot stat
