Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Miele Vented Tumble Drier (T7734) Problems
- This topic has 12 replies, 2 voices, and was last updated 7 years, 5 months ago by
bisebreath.
October 14, 2018 at 6:53 pm #94855
bisebreath
ParticipantI’ve had this tumble drier for a good 10 years or so now and it has worked perfectly up until now. It has just suddenly decided to start cutting out as if the power is turned off. It has been resetting after a while but has now just given up the ghost… Does anyone have any ideas before I call out a pro?
Thanks Pete
October 14, 2018 at 9:20 pm #458563electrofix
Moderatorfirst thing to try is plug it in another socket
October 15, 2018 at 8:12 am #458564bisebreath
ParticipantThere’s no problem with sockets. I tried it again last night and it starts fine, heats up and dries for about 10-15 minutes but then just totally shuts down as if it’s been unplugged….
October 15, 2018 at 8:31 am #458565electrofix
Moderatorand sockets can go faulty like that which is why I said it
October 15, 2018 at 11:07 am #458566bisebreath
ParticipantReally? OK, I’ll try a different socket then…… thanks
March 8, 2019 at 4:42 pm #458567bisebreath
ParticipantI sorted the above problem. Basically the air vent to outside was suck shut so no vented air could escape. I’ve not got a new problem however….
The Drier turns on and make the usual heating noises but there’s no rotation. Is this something as simple as a drive belt failure or something more sinister?
Thank you Pete
March 8, 2019 at 8:43 pm #458568electrofix
Moderatorcould be a belt. you will have to strip it to find out
March 9, 2019 at 7:19 am #458569bisebreath
ParticipantIt is. Having trouble finding the spare part though. Will speak to Miele on Monday as the usual spares websites don’t appear to stock it…. Thanks Dave
March 9, 2019 at 10:28 am #458570electrofix
Moderatorto be honest forget the spares websites with miele as most times they are cheaper on gen parts
March 16, 2019 at 10:14 pm #458571bisebreath
ParticipantDave, Can you help me taking the thing to pieces so i can get the new belt around the drum? I’ve taken top, sides and front off but there is another frama that is holding the drum tight. Cant see a way of loosening it….
March 16, 2019 at 10:36 pm #458572electrofix
Moderatordon’t know quickly its something I would have to see it
there is a site called manualslib which can sometimes have tech manuals.
cant find yours but another one reminded me of something but don’t know if yours is covered by it
manual I found is here https://www.manualslib.com/manual/889933/Miele-T-15xx.html?page=30#manual
and part way through I found
March 16, 2019 at 10:49 pm #458573electrofix
ModeratorI have deleted your other thread there is little point in duplicating things
March 17, 2019 at 12:12 pm #458574bisebreath
ParticipantDave,
That’s a great help thank you. I’ll try and follow those instructions..
Regards Pete
