Miele W 2241 – First use – Flashing Rinse light
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele W 2241 – First use – Flashing Rinse light
  • #90485
    itwasgood
    Hi All,
    Inherited a brand new Miele W 2241. Installed it and as per instruction manual set out to run it empty without any detergent or clothes. The manual indicated that for safety reasons spinning is not possible until the machine has been prepared for first time us and spinning is activated by running a wash program.
    After the water is drawn into the machine it proceeds to the next step at which point the rinse button begins flashing and nothing further happens.
    I am trying to determine if this is the ‘spinning safety lock’ mentioned in the instructions or whether this is another issue altogether.
    Any help would be immeasurably helpful!
    Thanks.
    (i’ve copied the manual section referenced below)
    For safety reasons spinning is not
    prepared for using for the first time. To
    activate the spinning function you must
    run a wash programme without laundry
    and without detergent.
    Using detergent could result in an
    excessive build-up of foam.
    This also activates the ball valve. The
    ball valve prevents detergent escaping
    from the suds container into the sump
    during a wash programme, thus making
    maximum use of the detergent.
    ^ Open the stopcock.
    ^ Press the I-On/0-Off button in.
    ^ Turn the programme selector to
    Cottons 40°C.
    ^ Press Start.
    When this programme has finished turn
    the programme selector to Finish. Your
    washing machine is ready for using for
    the first time.
    #444951
    Re: Miele W 2241 – First use – Flashing Rinse light
    did it empty ?
    where is the drain pipe plumbed into ?
    itwasgood
    Hi! Thanks for the reply.
    Yes it emptied, effectively skipping the cycle.
    The drain pipe is plumbed into a dedicated drainage pipe beside the machine.
    #444953
    thought it may be a drain problem but No
    Miele will know how old the machine is so try ringing them and ask
    when you ring have the model and serial to hand in case they ask
