miele w 806
  • #55527
    Cras
    can anybody tell me if there is supposed to be a bung in the end of the drainage tube from memory i thought not , but at the moment when you start to fill this it poors water straight out the drainage tube any advice gratefully received thanks Cras
    #324229
    Re: miele w 806
    drainage tube?
    you mean on the filter? then no bung, the filter is not in tight enough or a seal problem with the filter, they are nasty things to get right.
    #324230
    Cras
    Re: miele w 806
    thanks, lots of limescale build up in the filter housing so i presume a new housing is required ,i seem to remember changing one many moons ago for the same problem, things slowly come back to me 😀
